Circuit to remotely show incandescent mains bulb failure?
Danko
Joined Nov 22, 2017
2,247
In the post #38 circuit, when the lamp is working there is about 130mV rms across the piezo. Is that likely to produce an annoying background sound?
To answer your question I used circuit below and made sound box, using medicine jar, to increase output.
Threshold of sensitivity for me was about 10 cm (from sound box hole to ear).
I heard soft 50 Hz sound.
For younger people threshold was up to 50 cm.
They heard crisp sound.
Sound box:
djsfantasi
Joined Apr 11, 2010
9,237
If you could accept an optical warning instead of an audible one, then just a standard 6V 6W bulb in series with the heat lamp might suffice. The bulb would be under-run at only 0.75A so should have a long life.
<off-topic>
The TS already has an optical warning of a mains incandescent light failure.
The light bulb is dark!
Oh! Remotely...
Nevermind
</off-topic>
