Circuit to push 5 momentary button switches in the right order to get an output.
petesignals
Joined Aug 28, 2018
looking for a circuit that, when you push 5 momentary switches and let go in the right order so you get an output. Each switch circuit output should input the next circuit plus it's own switch output to enable that switch circuit output and so on till all 5 are pushed. would like to keep this as simple as possible.
dl324
Joined Mar 30, 2015
18,310
Welcome to AAC!
I don't understand what "next circuit" means. Post a block diagram or flow chart showing the functionality you want.
danadak
Joined Mar 10, 2018
4,057
Do they have to be momentary Push Buttons or push on push off type ?
Is there a timeout limit from push of first button to last, if not completed within
a time window whole process is reset ?
Do you want the allowed sequence programmable, ability to change it ?
Of course with a UP this is a trivial problem, is that being considered ?
Regards, Dana.
AnalogKid
Joined Aug 1, 2013
12,118
What happens if a switch is pushed out of sequence? Does the circuit just sit there waiting for a correct input, or does it reset back to the beginning of the sequence.
You will save a lot of back and forth questions if you tell us what the application is and post a block diagram of the operation sequence. There are several very smart people on this forum who don't like to play 20 questions.
ak
petesignals
Joined Aug 28, 2018
My bad. It's for a puzzle box for my grand kids. Ten pushbuttons on top. I don't want them to stay on. Button triggers a latching circuit whose output goes to the next latching circuit along with the output of the next button and so until 5 buttons are pressed in the correct order and an led lights.
AnalogKid
Joined Aug 1, 2013
12,118
Only one LED?
If so, then this is a sequential lock circuit problem. There are many circuits on the innergoogle for this: relays, neon bulbs, weird 60's silicon bilateral switches, SCRs, transistors, flipflop ICs, and of course a microprocessor.
However, a lock circuit resets whenever an incorrect switch is pressed, and gives no indication of the reset to improve security against random fishing.
So, when the kid gets buttons 1 and 2 correct, but misses 3, what should the system do?
ak
petesignals
Joined Aug 28, 2018
nothing happens until the right combination of buttons are pressed. They find clues around the house and when all are found they try to figure out what the correct numbers are to the switches. I'd like to replace the led with a magnetic lock to open a door on the box and a prize to be found.
dendad
Joined Feb 20, 2016
4,637
This will be a lot easier to do with an Arduino. Then it is changeable too.
An addressable RGB LED could be used to give colour coded hints and you could add sounds too. Lots of stuff to make it more interesting.
AnalogKid
Joined Aug 1, 2013
12,118
3 dual D-type flipflops
5 switches
7 resistors
1 LED
1 2N7000 transistor to drive the LED (and, maybe, solenoid)
4 capacitors
There is no need for switch debouncing. 3 caps decouple power to the chips, 1 is for a power-on reset. Does this sound like something within your skill set to assemble on perf-boad?
ak
Picbuster
Joined Dec 2, 2013
1,058
Pic 16f690 , mcp1705 , 5 leds + resistor, one buzzer + resistor, two caps., prog connector and some wire
10 lines of programming.
Picbuster
danadak
Joined Mar 10, 2018
4,057
PSOC, state machine wizard, no programming.
Here is example doing a traffic light controller. But principles common
with what you are trying to do.
Regards, Dana.
ScottWang
Joined Aug 23, 2012
7,500
If you use uC maybe more easier, if you want to use some flip flop ICs as CD4013 then the circuit as below or you can do some modify.
The RC circuit are used for the guessing delay time, t = R*C*(0.8) = 5.44 sec, you change the RC constant, if you don't want to use that function then you can cancel them, and the reset pin R1~R5 do some change as the U3B added a 10K and a push switch to reset the win state and the Led6 will be turn off, DIP Sw1~Sw5 are used for select different number(The order of Push Sw1~Sw5), and the DIP Sw5 was used for setup the first number(switch) of the puzzle, the Led6 was used for the win time when press all the order of number(switch) is right then Led6 will be light up.
5 momentary button switches in the right order to get an output-03_ScottWang.png
38,492
So I assume you want to be able to change the order of the correct numbers for the next game(?).
If so Dd's combination lock circuit could be changed by having the switches connected to jumper wires, allowing them to be connected to the 4022 outputs (connected to a header socket for example) in the desired sequence.
