I have an old exercise bike which doesn't have the driver board. It only has an alternator and 2 big power resistors (load). I expect to build a simple controller to save the bike. I attach a circuit that I made in which I think to control the field voltage by using PWM from Arduino (let's say). I can, for example, use a potentiometer to gradually vary the resistance of the bike. Do you think the circuit could work? What improvements can be made? I look for a cheap solution since it's an old bike.
Note: The rectifier is inside the alternator, so the alternator outputs a DC voltage.
