Actually the motor will run continuously and after a dealt of 2 second relay should triggered and open the circuit so that motor will not run until main power supply is off. Timer will reset when main PS is off.Depending on how you want to trigger it.. Make the 47K resistor on pin7 a 22k pot, with a 1k in series ..
There are several designs.....
Means changing 100uf capacitor and 2K resistor can vary the delay time right? But then what is the role of 22K pot Mr. Dodgydave is saying about?Calculator here, its the resistor and capacitor on pins 6,7
http://www.csgnetwork.com/ne555timer1calc.html
Adjustability. You can dial in the exact time you want the delay to be.what is the role of 22K pot
No! 100 uF capacitor and the 47K resistor,Means changing 100uf capacitor and 2K resistor can vary the delay time right? But then what is the role of 22K pot Mr. Dodgydave is saying about?
Yes I want the motor to run for 2 seconds then shut down until power resets.Adjustability. You can dial in the exact time you want the delay to be.
Quick question for you: You want the motor to run for (oh, lets say) 2 seconds then shut down until power is recycled? Or do you want the motor NOT to run for 2 seconds then start up afterwords?
Yeah 2 second is not necessary 5 seconds will work fine.Why 2 seconds? Can you live with 4 or 5 seconds or slightly longer? How tightly are you constrained to 2 seconds?
[edit] Well I suppose that's a moot point. With the circuitry DodgyDave gave you - that should solve your problem. You can precisely dial in the delay with the pot.
OK I will try this. Thanks for helpNo! 100 uF capacitor and the 47K resistor,
if you want 2seconds then you need 100uF cap and 20K resistor, so i would put a 22K preset and a 10k resistor in series to give you better results.
But your circuit isn't using 555 IC. I want to built whole circuit with 555 IC only. Thanks for advice.Followup thought on the circuit I provided: if you're powering the relay from a low voltage source such as 12 volts and want to switch a motor running at high volts AC then the relay you'll want to use will have to be a double pole double throw type so you can isolate the high voltage from the low control voltage circuitry.
| L | Bi-directional current limiting circuit? | Power Electronics | 43 | |
| C | Schmitt trigger debounce circuit problem(s) | Digital Design | 15 | |
| F | Basic Amp Circuit Question | Homework Help | 4 | |
Capacitor discharge circuit in modern multimeter | General Electronics Chat | 31 | |
| L | Did you ever make a circuit and gift to your loved one? | Off-Topic | 15 |
