Circuit help for 12v motor on exhaust
Williamsa
Joined Jul 17, 2018
15
Hi, new today and first post... I need somebody’s help.
I have an electric cutout on my exhaust which bypasses the muffler when I choose to. It came with a wireless remote that when I click it the motor opens the flap all the way and click again it closes.
I want to change that to a toggle switch so I can open it as much or as little as I want.
I need a basic circuit where I move the toggle up and it opens, down and it closes and centre.. nothing. The car supplies 12v and the motor is 12v. Although the car when running shows 14.1v (will this be an issue?) could someone help me with this circuit.
The kit came with a little box that controls all the electrickery currently but I want to remove it.
Williamsa
Joined Jul 17, 2018
15
Is that road-legal where you live?
Welcome to AAC!
Yes, as it’s closed on the road and going through the standard muffler. When on private roads and tracks I can open it to allow the exhaust to flow better.
Do you have any knowledge as to my circuit help?
Alec_t
Joined Sep 17, 2013
15,145
How about this, using a 2-pole 3-throw switch (centre-off)? It's as basic as it gets.
However, you will probably need to incorporate limit switches to switch off the motor at the fully-open or fully-closed position of the cutout. What current does the motor draw when stalled?
Williamsa
Joined Jul 17, 2018
15
That looks great, although I shouldn’t. Need limit switches as I can hear when it’s fully closed or fully open quite well so I’d just take my finger off the switch. Can I get a switch that centres automatically when I take my finger off? I’m not sure on the motor load or what you mean by stalled. I’ll have to take a look on the controller that came with the kit and see if it’s got any info on it.
Reloadron
Joined Jan 15, 2015
7,893
Yes, what you want is typically called a MOM-OFF-MOM DPDT which will give you the center position OFF. Depending on your location they are pretty common and available from plenty of manufacturers. The MOM is for Momentary and the switch on release springs back to the center off position. You wire it exactly as Alec shows in the drawing. Just make sure the switch is rated for the cutout motor current which likely isn't very high.
Ron
Williamsa
Joined Jul 17, 2018
15
lets say I cannot find the current rating. What would be a safe amps given the motor is doing very little work and it’s about the size of a D battery.
ian field
Joined Oct 27, 2012
6,536
You'd do better with the snail cam type used in the Yamaha YPVS. Theirs is controlled by the ECU and has feedback to manage exhaust port opening size. You might even be able to do it with an RC servo if you figure out linkages that don't conduct enough heat to melt it.
Williamsa
Joined Jul 17, 2018
15
I’d love to have something like that but money’s tight. Got one of them eBay type things but the quality of the item is good. Just doesn’t do what I want. It’s either fully open or fully closed and when it’s open all the way it’s to darn loud.
ian field
Joined Oct 27, 2012
6,536
just like the earlier air cooled RDs - quite a few of the LC models became untidy heaps of wreckage at the roadside. salvage could be an option if you have to tools to make it fit your application.
Reloadron
Joined Jan 15, 2015
7,893
Most of these which come as a kit use either 1 or 2 small DC high torque gear motors. Most kits, and this is pretty generic, include an inline fuse. Now if your system has a fuse do you know what it is rated at? That will give you an idea of what the motor max current would be.
Ron
Williamsa
Joined Jul 17, 2018
15
Ron
It came with a box with all sorts of things going on inside it. I’ll open it up and take a look. Thanks for the info.
Williamsa
Joined Jul 17, 2018
15
Let us know because if it has a fuse it will make it easier to make an educated guess as to a switch.
Ron
I’ve been searching google and the same sort of more expensive cutout exhaust uses a switch to open and close it and on the side of a few of them it says 3A250V
Reloadron
Joined Jan 15, 2015
7,893
Pretty standard 3 amp fuse which sounds about right. Any DPDT Momentary - Off - Momentary should work as long as it can handle about 5 amps should do fine. Keep in mind these motors are normally gear motors designed for high torque. Without limit switches when you exceed the throw of the butterfly in the pipe(s) the motor goes into a stall so motor current will increase dramatically and there is a good possibility you will blow a fuse. There is also a possibility that less any fuse you could strip a gear head. I would fuse it with maybe a 3 to 5 amp inline automotive type fuse and see how it works out. Not knowing your location any electrical parts house should have the switch and if you get a switch with 1/4" spade lugs any auto parts store should have crimp connectors. They may also have a switch and inline fuse holder.
Ron
Williamsa
Joined Jul 17, 2018
15
This is the module that came with the item, there’s no inline fuses. I have it wired in to my cigarette lighter then it goes through this device and straight to the motor. And a little remote with 2 buttons opens and closes it. Also the three pins that haven’t got anything soldered control the device to but it still opens and closes fully. So I would have to remove this box and just make the circuit you guys have mentioned 1A3F66D2-E69E-46D2-899D-C3EA87263E5E.jpeg
