Circuit for Ramped Sine Wave Output
ColStewart
Joined Jul 30, 2019
1
I need to create a sine wave output of about 300Hz with ramped AC output starting at ~ 0.01 V p-p increasing to 10 V p-p over about ~13 seconds
I have found some circuits for ramp functions and also for sine wave generators but I have not been able to couple the two together with any success.
This is my first electronics project in many years, so I am still pretty low on the learning curve.
Any suggestions would be most appreciated.
Many Thanks
Bernard
Joined Aug 7, 2008
5,784
Just to open the door: Start with Op Amp. fed with your 300 Hz. oscillator- maybe 1V PP. Use a LED to CdS.
photo coupler for Op Amp feedback. Use a 555 ramp generator to drive the LED. Input resistor around 100K,
almost dark coupler feed back 1M= output of about 10V PP. Drive LED harder & feedback drops to 1k , output about .01 V PP ??
Hymie
Joined Mar 30, 2018
1,347
There must be an op-amp on the market with a gain set by an external voltage (if there isn’t one, I’ve just invented it).
Feed the 300Hz sine wave into the op-amp and supply the op-amp gain input voltage via a suitable resistor charging a suitable capacitor to give the required gain ramp time.
LesJones
Joined Jan 8, 2017
4,509
An alternative approach as the frequency is fixed is to generate a ramped square wave which would be easier and filter the output with a LC filter (Or you could use an active filter.) tuned to 300 Hz.
Les.
danadak
Joined Mar 10, 2018
4,057
Picbuster
Joined Dec 2, 2013
1,060
Many Thanks
Use a microchip pic + dac + opamp as buffer
output Amplitude = offset+ A . sin(t) A amplitude .
or when you need a separate DAC remove offset and use opamp to create an offset.
300 is slow and no problem to calculate or use a table.
Link a to ramp as function of period or as function of t. ( last one allows you to create a periodic wave form)
doing t in big steps you are able to build different wave forms like triangle ++
Picbuster
