Still trying to build this circuit, assume the primary of the ignition coil connects across C8. (Thinks it 10nf 1kv but can’t make it out) Still don’t understand the purpose of the spark gap across D1, or the neon, why have both? Is this even worth bothering with as I want to energise at least 500m of fence. Also why on earth did the designer specify a surface mount transistor mmbt2222, when everything else isn’t ? Are there any designs (without relays but using vehicle IGN coil) that are proven and can supply a useful length of fence to keep horses in?High there! I hope you are doing well...
The circuit runs on 12V (batteries), making this a very portable fence energizer solution. It uses 2x 555 timers, one runs in astable mode and is used to generate the frequency interval, while the second one controls the pulse length and so the output voltage. A calculator for the 555 timers can be found here The updated circuit diagram for this version of the circuit is oavailable:
Here are the Eagle files, with both the SCH and the PCB layout: fence-4.3-orig
alternatives, such as the double timer 556, we can shrink this circuit even further, without making any compromises. Here is an improved version that I’ve just designed and tested with excellent results
The eagle files: fence-4.2
Both the designs can operate on battery and have low power consumption.https://www.pocketmagic.net/electric-fence-circuit-for-perimeter-protection/
Go to this link, and read everything three times... at least to page 4. oztules is the designer (attached hand-drawn schematic).Still trying to build this circuit, assume the primary of the ignition coil connects across C8. (Thinks it 10nf 1kv but can’t make it out) Still don’t understand the purpose of the spark gap across D1, or the neon, why have both? Is this even worth bothering with as I want to energise at least 500m of fence. Also why on earth did the designer specify a surface mount transistor mmbt2222, when everything else isn’t ? Are there any designs (without relays but using vehicle IGN coil) that are proven and can supply a useful length of fence to keep horses in?
fixed itHello,
@Hamlet , There is a picture that does not show.
It is likely stored on the web somewhere.
Always try to upload the pictures to the forum to avoid these problems.
Bertus
Had a look but seems to be more about the actual fence than the energiserTake a look at this and tell me what you think?
https://www.doityourself.com/stry/making-an-electric-fence-charger-with-an-ignition-coil![]()
