Circuit Design - Automatic Switching between two DC Supplies
Joe747
Joined Sep 20, 2023
7
I have 2 DC supplies:
1) Supply from a regulator ( LM7809) supplying 9V
2) Supply from a Lead Acid battery ( 12V )
Requirements :
*When the supply from the Regulator stops supplying any voltage the back up supply (battery) should start supplying automatically.
* There should be an LED indicator to show when the battery is supplying
Is it possible to use a Relay switch for this, and how can it be set up ?
Any sort of guidance guidance will be appreciated
WBahn
Joined Mar 31, 2012
33,205
A lot depends on the details of what is needed.
What is powering the regulator?
How much current does the load need?
Does the voltage to the load need to be kept at 9 V when the regulator stops supplying power, or is it okay to all of a sudden start supplying it with 12 V?
Does the indicator showing that the battery is supplying power need to be lit even if the battery isn't actually supplying any power (for instance, if the regulator power goes a way but the load is removed and, hence, not drawing any current at all).
What is the lowest voltage to the load that is acceptable?
There are a number of different ways to approach this problem, some very simple and some much more complicated, and the answers to questions like this are what determine which approaches can/should be ruled out and which ones should be considered first.
Joe747
Joined Sep 20, 2023
7
Thank you Wbahn for the reply
*The regulator is the final component from my ac to dc supply.
* The load current can work of minimal current.
* The voltage to the load need to be kept at 9V
*The LED must only be lit when the battery is supplying
* The voltage at the load should be as close to 9v as possible
Furthermore, the battery should charge when not supply.
Thank you
vu2nan
Joined Sep 11, 2014
357
Two Schottky diodes and an electromagnetic relay would be required.
The power supply predominates on account of its higher voltage (14V).
The battery takes over when the power supply is off.
The battery is charged through resistor R1. It's resistance value decides the charging current.
Overheating of the regulator is avoided, with the resistor R2 limiting its input voltage.
The LED lights up, when mains power is off, indicating that the battery has taken over.
Nandu.
