Circuit analysis; what is the function of the capacitors in this circuit?
abdulwahab.hajar
Joined Jun 14, 2016
93
The circuit attached is a charger for lithium cells, I understand how the circuit generally works sort of....
but what was the need for the capacitors if I may ask? what is their role in the circuit?
Thank you
ericgibbs
Joined Jan 29, 2010
21,622
hi ah,
It is not primarily intended as noise prevention, but it will give some noise reduction at the higher frequencies.
Most regulators must be fitted with decoupling capacitors as close as possible to the regulator in order prevent oscillations/instability problems within the regulator.
It is good practice to fit these capacitors.
E
abdulwahab.hajar
Joined Jun 14, 2016
93
hi ah,
E
Thank you sir, it's really appreciated.
