Hi, I want to reduce DC voltage with -15 volt (bias voltage). For example, I have sine input wave with 0/30 volt DC amplitude and I want to convert to sine wave with -15/+15 volts amplitude, what the circuit or component used for this work? thanks.
The load is very low. About 20 watts. For use in piezoelectric.... thinking that a center tapped transformer could accomplish this ...
The output ground terminal would be the center tap on the secondary side.
It would necessarily have a 1:1 winding ratio. What is the load requirement, in watts? What will it be used for?
... see this reference:
https://en.m.wikipedia.org/wiki/Center_tap
There is frequently a safety hazard associated with these transformers since one side will likely be directly connected to a dangerous AC voltage source. It may be that a better choice would be what is called an isolation transformer, which insulates the secondary side from the primary side, and could potentially prevent a serious injury.
@mohammadreza emadi It is hard for me to be sure what you are asking for, but if it is what it sounds like, this advice it spot on. A simple DC blocking capacitor is precisely the way to do interstage AC coupling when there is a bias voltage that needs to be isolated.Use a capacitor to block the DC component, it will center the signal on 0V.
please send more information. thanks a lot.Use a capacitor to block the DC component, it will center the signal on 0V.
Hi, if i use the capacitor in this circuit, the voltage drop in exist in work and it's not good. can I use op-amp 741?Why not use the capacitor solution from #8? Other requirements for this?
Not. The output power of the amplifier is milliwatts. 1mW = 0.001WHi, if i use the capacitor in this circuit, the voltage drop in exist in work and it's not good. can I use op-amp 741?
