Christmas serial light
justin felix
Joined Jul 16, 2017
10
How does the Christmas light function with y803a cob how to replace that cob with other ic
Mod edit: Direct-to-mains power supplies are not allowed on AAC for safety reasons. JohnInTX
Ya’akov
Joined Jan 27, 2019
10,300
Welcome to AAC.
In order to get help you are going to have to provide more information.
What do you want to change about the lights, that is, what do you want the “new IC” to do?
We need photos of the board from the top and the bottom to see what the circuit looks like.
How are the LEDs wired in the string?
justin felix
Joined Jul 16, 2017
10
Welcome to AAC.
justin felix
Joined Jul 16, 2017
10
This LED flashing circuit blinks and glow in the following series.
  • Combination
  • In Waves
  • Sequential
  • Slo-Glo
  • Chasing/Flash
  • Slow/Fade
  • Twinkle/Flash
  • Steady On.
Components Required for Christmas LED String Circuit
  • SCR 1 and SCR 2 = PCR 406 PNPN
  • D1 = IN 4007
  • C = 10μF, 16 V
  • R1 = 2MΩ
  • R2 = 150kΩ
  • LED = 60 Nos
  • IC/Chip (Programmable) = Y803A
  • Tactile Switch = Pattern Change
  • Input Voltage
  • 220V, 50-60 Hz
justin felix
Joined Jul 16, 2017
10
Welcome to AAC.
  • Combination
  • In Waves
  • Sequential
  • Slo-Glo
  • Chasing/Flash
  • Slow/Fade
  • Twinkle/Flash
  • Steady On.
  • D1 = IN 4007
  • C = 10μF, 16 V
  • R1 = 2MΩ
  • R2 = 150kΩ
  • LED = 60 Nos
  • Input Voltage
  • 220V, 50-60 Hz
Ya’akov
Joined Jan 27, 2019
10,300
Well, your problem is that the Y803A COB has those functions built in. To replicate those patterns you will need to program an MCU (microcontroller) to duplicate them. It's not that hard, but you will need to work out a fair bit of code with so many patterns.
There will be no direct replacement for the COB, it's a very specialized chip and that circuit is an application of it. You could build a very similar circuit, if not identical, but you still need that MCU. I think an ATTINY85 would be good enough.
justin felix
Joined Jul 16, 2017
10
Thanks for the info
Should I be able to control voltage using resistance for this ic
JohnInTX
Joined Jun 26, 2012
4,787
Mod edit: Direct-to-mains power supplies are not allowed on AAC for safety reasons per the Terms of Service and User's Agreement. Images deleted.
This thread may continue if safe power supplies are used.
DickCappels
Joined Aug 21, 2008
10,661
Here is the datasheet
By the way, the circuit that was posted here is dangerous in many respects, the capacitor in series with the AC line should have a bleeder resistor across it (470k for about a 1 second time constant) to reduce chance of electrical shock and a fusible resistor (100 to 200 ohms) in series with the AC line to protect the circuit from damage when AC if first applied and to protect against overload.
You would do well to isolate the circuit from the power line with a 1:1 transformer.
DickCappels
Joined Aug 21, 2008
10,661
Look at the last page of the datasheet carefully. I can operate from DC.
The
PIC12(L)F1822/PIC16(L)F1823 Data Sheet
, file
name 400041413E.pdf (4.2 MB). At the Microchip
home page, use the Search Data Sheets box to look
for 12F1822
