Choosing right Gate driver for MOSFET ?
mishra87
Joined Jan 17, 2016
1,063
Hi All,
I want to drive 24V@3A dc pump using MOSFET through microcontroller.
Now I have some confusion in gate driver selection.
I do not know when to choose Mosfet gate driver.
Selecting dedicated gate driver IC costing more.
Could anybody suggest me some low cost solutions on the same.
Regards,
jpanhalt
Joined Jan 18, 2008
11,087
That is an N-channel mosfet. Are you using a full-bridge, half-bridge, or just single mosfet? Will its source by ground/common or connected to the load? Please show your circuit.
What will be the switching frequency?
mishra87
Joined Jan 17, 2016
1,063
No switching frequency . it is to be driven from MCU DO at 3.3V logic level.
e.g.
jpanhalt
Joined Jan 18, 2008
11,087
The datasheet I found did not show performance for Vgs for less than 4.5 V. Do you have its characteristics for a gate voltage of 3.3V? If not, you will probably need to use a driver. Since you apparently are just using it as an on/off switch (i.e., switching speed is not that important), a simple level shifter to 5.0 volts may work, or find a mosfet that is characterized for your voltage.
As with most devices, the package you use will make a difference in the power it can dissipate. So, tell us the package.
mishra87
Joined Jan 17, 2016
1,063
VGS(th) = 1.2V min so i think mosfet will turn ON with 1.2V
SO my question when i should mosfet drive
OBW0549
Joined Mar 2, 2015
3,565
No, it will not. Read the data sheet CAREFULLY: note that it defines Vgs(th) as the gate-to-source voltage which will cause the drain current to be 250 μA. In other words, Vgs(th) is the gate voltage at which the MOSFET begins to conduct-- not the gate voltage which will allow it to conduct 3 amps, which is what you need.
If your logic is operating at 3.3 volts, you will definitely need to use a gate driver of some sort to boost the drive voltage.
38,832
If your particular MOSFET has the minimum VGS(th) of 1.2V it may turn on sufficiently at 3.3V to carry the motor current, but if you happen to get one with the maximum VGS(th) of 2.5V, it won't.
You can use an NPN BJT to level shift your 3.3V signal to a higher voltage.
Do you have any higher voltages available besides the motor 24Vdc?
tindel
Joined Sep 16, 2012
939
Are you in love with that transistor? There are other transistors that will do 3A all day long with a 3.3V drive. This one has an Rds on of 68mohm @ 2.5V Vgs. This would save you the expense of an additional part, and you'd get a smaller footprint than with your original transistor.
You probably also want a resistor ~1kohms to limit the current through the micro during turn-on to an acceptable level. The gate of the transistor looks like a capacitive short when it charges. This will slow the turn-on but not to an appreciable level.
If you need a higher power transistor (due to high temp operation/derating) here is a list of about 45 others that might fit the bill.
mishra87
Joined Jan 17, 2016
1,063
No i have only 24Vdc and 5vdc on the board.
could you share NPN bjt schematic for my better understanding.
At-least i want mosfet with 4 times higher rating than rated current to avoid any stress.
Regards,
mishra87
Joined Jan 17, 2016
1,063
I do not understand mosfet is able supply 3A current at 1.2V VGS(th) and not at VGS(th)=2.5V.
mishra87
Joined Jan 17, 2016
1,063
I am not biased with that MOSFET.
I am free to select new part if somebody suggest good low cost part.
Vds should be 60V and ID=11/12 with low Rds ON
Regards
mishra87
Joined Jan 17, 2016
1,063
Most of MOSFET manufacture says ID at ambient 25 degC.
So it would be better if we choose some higher rated mosfet to provide enough headroom over temperature.
Regards,
bertus
Joined Apr 5, 2008
23,006
There are also manufacturers that show the absulute maximum currents at 25 °C and 100 °C.
Have a look at the IRL540 datasheet.
Bertus
mishra87
Joined Jan 17, 2016
1,063
maybe you can suggest some gate driver using discrete components to reduce bom cost.
38,832
Because a voltage of 3.3V-2.5V = 0.7V is not enough voltage over the threshold value to fully turn on the MOSFET.
It would need a higher applied Vgs to fully turn on.
it's the voltage above the threshold value that determines how well the MOSFET is turned on.
Below is an example circuit that uses a NPN BJT to level translate the signal without signal inversion.
R1 and R2 reduce the Vgs ON volage to keep it below the MOSFET maximum value (typically 20V).
mishra87
Joined Jan 17, 2016
1,063
Still i do not agree with you on MOSFET Turn ON condition.
VGS>VGS(th)
So VG-VS>VGS(th)
3.3-0V> (2.5V)
3.3>2.5V so i assume mosfet gets fully turned ON.
Thanks for sharing simulation results.
Could you suggest some good mosfet rated for 11/12A ID with VDS=60V
Regards,
Regards,
