choosing the right debug tool for different embedded failures
Embededd
Joined Jun 4, 2025
212
I’m trying to get better at choosing the right debugging approach when something goes wrong in an embedded system. Imagine a situation where you suddenly hit an issue, maybe the code starts misbehaving, the clock isn’t set right, the power line looks noisy, a GPIO is mapped wrong, UART communication is off because of a baud mismatch, or some protocol just begins acting strange. In those moments, I often pause and wonder which tool I should reach for first: UART logs, a hardware debugger, a logic analyzer, or an oscilloscope.
My basic understanding is that each tool reveals a different layer of what’s happening. UART prints show if the code flow is even reaching where I expect. A hardware debugger lets me see what the CPU is actually doing and check registers. A logic analyzer helps verify if the protocol timings and signals are correct. And the oscilloscope helps with analog issues like power quality, noise, and clocks.
This might sound like a stupid question, but I just want to understand how experienced engineers actually approach this in real projects. When you run into a issue, how do you personally decide where to start? Do you follow some kind of mental checklist,
I’d really like to hear how experienced engineers think through this,
lichurbagan
Joined Jul 4, 2025
137
Start with the simplest checks before deep debugging. Use UART logs to confirm basic code flow. If nothing prints, attach the hardware debugger. Check registers and fault states immediately. If firmware seems correct, inspect digital signals.
Use a logic analyzer for protocol timing issues. Verify chip-selects, interrupts, and bus activity. If signals look clean, suspect analog problems. Use an oscilloscope for power and noise checks. Always check what changed just before the failure.
trebla
Joined Jun 29, 2019
599
Simplest method to ensure that the clock frequency is right and the MCU is running, is make a LED blink at known period. You can also use a LED for testing that the program passes certain point.
Rf300
Joined Apr 18, 2025
131
If you are debugging embedded HW, the very very first thing you need is a digital oscilloscope with 4 channels and at least 100 MHz bandwith for debugging signals up to the 10 MHz region. If you have faster signals, you need more bandwith, but more bandwith means more money. So you can measure voltages, signals shapes, timings and relationships between different signals. Then I would recommend a DVM for more exact measuring of DC voltages and finding shortcuts.
For downloading and debugging the FW you usually need an IDE together with a debugging adaper. For the STM32 family there exists a free IDE (Cube IDE) and on STM32 evaluation boarxs, there is a JTAG/serial wire debugging adapter.
For debugging FW you can use the IDE for debugging, setting breakpoints and stepping throug your code. If your controller has a free UART, you can use it for "printf-debugging ". Simply connect a USB to TTL serial converter to your UART and you can display debugging messages on your PC with a terminal program like PuTTY. A logic analyzer is usually overkill, in almost 40 years of professional embedded development I used it less than 5 times. Sometimes you can get additional digital channels for your oscilloscope for a moderate amount of money.
