Choosing components for switching circuit
nothing909
Joined Nov 5, 2016
54
I'm building a switching circuit for a switched reluctance motor.
I have an open collector for the interface device, an optocoupler for the isolation device and an IGBT for the switching device.
How do I choose a specific open collector, optocoupler and IGBT? What am I supposed to be looking at in datasheets that will show that me what is suitable and what isn't?
nothing909
Joined Nov 5, 2016
54
There's the circuit below. The parts I have chosen are parts that have been suggested to me, but I'm writing a report and I don't know how to justify why they are suitable. What should I be looking for in the datasheets?
Moderators note : Shown image full size
bertus
Joined Apr 5, 2008
23,026
The term "Open Collector" only tells you someting about the output of a device.
This device can be a transistor, comparator or gate.
Bertus
R!f@@
Joined Apr 2, 2009
10,014
The open collector logic gate should be able to drive the opto LED.
To find the desired info you need to look at the opto datasheet.
In that you will find the LED's forward voltage and it's current.
Those figures will tell you what is the value of the resistor to use for the LED current limiting.
The IGBT is always rated double the motor supply voltage and the motor current (for a safety margin ) And of course how fast you need to switch the motor like PWM.
Once you know the motor V, I and PWM (if you are using ) you need to look into the IGBT data to see if it can withstand the V and I and operate at the desired switching frequency.
R!f@@
Joined Apr 2, 2009
10,014
There's 12V going to to motor and it requires 3A per phase.
What do you mean by " per phase"
Your diagram does not show more phases but a just a DC motor.
A stepper uses more than one phase.
A 3 phase motor uses more than 1 phase.
The requirements of the task aren't too specific. The motor just needs to operate, that's it.
Find an IGBT that can operate at around 50 to 60 V minimum and handle atleast 6 A
nothing909
Joined Nov 5, 2016
54
Sorry for asking so many questions, I just don't have a clue how to look at data sheets.
What specifically am I supposed to be looking at on the IGBT data sheet?
R!f@@
Joined Apr 2, 2009
10,014
Where did you learn electronics ?
Are you trying to make a circuit when you have no idea on choosing components and you do not understand datasheets?
How do you expect to troubleshoot when you got a problem ?
Are you trying to make a 3 phase motor drive or a stepper drive ????
nothing909
Joined Nov 5, 2016
54
It's a 6/4 pole switched reluctance motor.
I've just never had to use data sheets before to choose components. I know how the components operate, just not too good at looking through data sheets.
Looking at these values, this would definitely be suitable for the application, yes?
R!f@@
Joined Apr 2, 2009
10,014
The TO-220 one will suffice
I will chose a the metal tab one for better cooling
What is your switching frequency ?
