Hi all,
Looking to posts on this forum and others, most questions are about calculating the caps needed for a given crystal. However, I'm trying to figure out which values mentioned in a chips datasheet are the most important ones when choosing the crystal.
Say I'm creating a circuit for the LAN9512 chip. The datasheet (http://ww1.microchip.com/downloads/en/DeviceDoc/00002304A.pdf) does a crystal specs recommendation on page 43:
25Mhz, CO|Shunt @ Nom 7pF, CI @ Nom 20pF, Drive @ min 300mW and ESR @ max 50Ohm
I'd like to know which values given by the chip manufacturer are the most important ones which should match. Lets take this crystal: MCRS025000F183000RR (datasheet: http://datasheet.octopart.com/MCRS025000F183000RR-Multicomp-datasheet-8454482.pdf)
Could I use this crystal for this chip? Or should I match the CI .. or CO|Shunt, drive, ESR or should even every value match?
I hope I created this question with enough (useful) info. And hopefully I didn't overlooked an existing post. If so, please let me know.
Regards,
Onno.
Regards,
Onno.
