stepping motor - how to choose properly
thor21
Joined Sep 29, 2024
435
i have locker on my door; to lock / unlock it requires 360deg movement. The "strength" is similar to the movement of the key in the locker.
Is there some guideline how to chose a stepping motor for such a use-case?
See the photo of the locker; the white button is the one that has to be rotated 360deg left/right.
Thanks!
thor21
Joined Sep 29, 2024
435
@MaxHeadRoom
thanks will check that motor.
maybe also question: how many Bipolar Torque (oz-in) / holding torque?
How? That would be good question. No idea now - any recco?
thanks!
thor21
Joined Sep 29, 2024
435
thats what said chatgpt
Typical torque to turn a household key is roughly 40–200 in·oz (0.28–1.41 N·m) depending on lock type and condition.
For planning actuators or motors, pick a driver with 2–3× margin (e.g. a 150–600 in·oz motor for tougher locks)
so assuming 3x margin = 4.23 N-m (600 in-oz)
which sounds like a nonsense
Reloadron
Joined Jan 15, 2015
7,954
Thanks!
Going by your image I would get a torque wrench having a dial indicator and turn the lock to get a feel for the required torque you will need and figure a 20% overhead.
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,836
You can also rig up a defined length of Cane/Rod and place a spring scale on the end and pull untill it moves the lever, Take a reading.
BTW, if no gearing is involved, i.e. Low motor RPM, you just need to provide the exact voltage for the motor rating to drive it; no driver required .
thor21
Joined Sep 29, 2024
435
By gearing you mean? I
I need to do 360deg movement.
Also that button is install see photo, so question would be if its possible attach motor shaft to it.
Thx
MaxHeadRoom
Joined Jul 18, 2013
30,836
@MaxHeadRoom does the bipolar provide double shaft?
thx
still not sure how to attach the motor to the mentioned button.
Maybe look at adapting the operator in Post #10 to the end of the shaft?
You can get double shaft in most sizes, e.g., Bi-polar NEMA17.
A little 8pin picmicro would do the control job very easily, if you were familiar with them.! ;)
or 8825 for control.
What initiates the open/close action, BTW?
8825...........................................
thor21
Joined Sep 29, 2024
435
not sure how?
I need to control one security lock on my door ; open/close.
Controlling wise - ideally able to integrate with home-assistant. .. .so some esp32 or something other?
MaxHeadRoom
Joined Jul 18, 2013
30,836
not sure how?
How? In the order of a little mechanical modification/engineering? ;)
Not that familiar with ESP323, but at first glance, seems to be a few aids (modules) out there that may help. ?
