stepping motor - how to choose properly
panic mode
Joined Oct 10, 2011
5,234
thats what said chatgpt
Typical torque to turn a household key is roughly 40–200 in·oz (0.28–1.41 N·m) depending on lock type and condition.
For planning actuators or motors, pick a driver with 2–3× margin (e.g. a 150–600 in·oz motor for tougher locks)
so assuming 3x margin = 4.23 N-m (600 in-oz)
which sounds like a nonsense
AI is bonkers... that would shear the key with ease.
A while ago i connected socket extension to a 800W servo motor and measured torque that my hand can hold.
shaft is about 5/8" (no lever action). and since it is smooth i put some masking tape on it for better grip. as i recall, the maximum I was able to hold was about 4.5Nm and that is probably 2x what average adult may do.
i would say that turning house key should be not more than 1/10 of that. even a stiff lock is maybe 2 in-lb (about 0.25Nm). that is enough to turn the door-knobs.
or... the best approach is to just measure it yourself.
panic mode
Joined Oct 10, 2011
5,234
yes, that should be plenty to turn the key (if that is torque that can move your knob). are you sure that it needs to to turn 360deg and not only 90 or 180deg?
MaxHeadRoom
Joined Jul 18, 2013
30,807
Here is the spring scale version, if you don't have a torque wrench.
  1. Set up the lever arm: Secure the object you are testing, such as a shaft, so that it cannot rotate. Attach your lever arm to the object.
  2. Attach the spring scale: Hook the spring scale to the lever arm at a precise, measured distance from the object's center of rotation. For example, hook it exactly 1 foot away.
    • Apply the force: Pull on the spring scale until the object just begins to rotate. Be careful to pull perpendicular to the lever arm to ensure an accurate measurement.
    • Read the force: Read the force measurement in pounds directly from the spring scale.
    • Calculate the torque: Multiply the force from the spring scale (in pounds) by the length of your lever arm (in feet).
      • Formula: Torque (lb-ft) = Force (lbs) x Lever Arm Length (ft)
      • Example: If you pulled with 50 pounds of force on a lever arm 1 foot long, the torque would be 50 lb-ft.
thor21
Joined Sep 29, 2024
435
Thats what i got from nuki:
The Nuki Smart Lock works with a force of 2Nm, this is about the force an adult has turning the key with one hand. So in principle, stiff doors are no problem for the Nuki Smart Lock.
http://nuki.io/
so i am confused with the assumption:
1.41 N·m ~ 200 oz-in
