Chip Replacement Selection for Old Electronics
johngalex
Joined Sep 7, 2013
9
Hi all - first post. I am a novice with electronics but a quick study and have been reading a lot to learn.
I recently purchased my dream vintage analog synthesizer - an Oberheim OBX. This was built in 1980 and is all discrete electronics. It has had it's power supply rebuilt and other items replaced / corrected prior to me purchasing it. I knew going in this would be a job to maintain - either professionally or hopefully by me if I can come up to speed. I plan to keep this beauty going for another 40 years.
It had two issues that I found - the filter envelope did not work and the cassette interface (yes, they used cassettes to save the sound presets in 1980) did not work. I have the schematics, so with a little trouble shooting and voltage tracing, I fixed both by replacing two bad chips (the chips are all socketed).
I have a general question - when choosing replacement ICs - if I find replacement parts with the exact same part number (CD4040BE, CD4049CN, MM80C98N, etc.), from know manufactures (TI, NSC, etc.), and purchase from a reputable distributor - does this ensure compatibility or do I need to read through all of the spec sheets?
I understand that the prefix usually stands for the manufacturer but sometimes other manufactures use the same number, the suffix could stand for buffered, etc. - all a bit too much for me right now to completely understand. Even if I read the spec sheets, I am not sure I would be able to make a decision if the differences were material. I am hoping an exact part number match will suffice...
Thanks for you help,
John
danadak
Joined Mar 10, 2018
4,057
In low speed stuff like this in general you should be OK.
Any mixed signal parts, like 4046 for example, maybe a little more challenging.
OpAmps for waveform generation I would also look a little closer at.
Regards, Dana.
Regards, Dana.
dl324
Joined Mar 30, 2015
18,454
For the most part, different manufacturers parts are interchangeable. But there are exceptions.
johngalex
Joined Sep 7, 2013
9
Thanks for the replies. That is what I thought.
I've been purchasing replacement ICs as spares and testing them by swapping them with a known working IC. I would then test the functionality of the keyboard. So far, so good...
John
