Yes. About 0.7V per diode only.And, also, if I am getting let's say about 35V peak to peak, won't the voltage drop across the rectifying diodes lower that down before it gets to linear voltage regulator?
How many diodes would i need to drop from 28vac to 24vac and what power should diodes be.Is here any gap between the core and the winding of the transformer?
If so, you could add turns of wire to hook in series with the other winding, but in reverse, to lower the output voltage.
Another option would be to take some turns off the transformer secondary.
Yet another way would be to connect a number of power diodes in series to drop the volts that way.
Bridge rectifiers may be used as the diodes. There are a few places to hook them in.
In series with the secondary AC, or from the bridge +ve out but before the capacitors.
If in the AC line, diodes both ways will be needed. Both options can use bridge rectifiers wired appropriately to drop the volts.
I will search today for some bridge rectifires in my parts bin and wait for tommorow so you could draw me that diagram thanks in advance.Disconnect the bridge rectifier "+" pin from the circuit.
Using a spare bridge rectifier as power diodes....
hook the "~" pins together. may not actually be needed.
"-" pin to the original bridge rectifier "+"
"+" pin to the filter cap where the original bridge was connected.
This will give you 2 dioded in series. Actually, 2 parallel pairs of diodes in series.
The voltage drop will be about 1.5V, so if you has 3 sets of these diodes (bridges) in series, that is 6 diode drops, it will lower the volts to the filter cap by about 4volts.
You could just put 6 power diodes in series but using bridge rectifiers may be an easier and cheaper way to get the power diodes.
A source of power bridge rectifiers may be old TV sets or computer monitors.
I'm in bed now and using the iPad but if you need a diagram I can draw one up and scan it in tomorrow.
Diodes and rectifires are rated for 3 ampsDo you have any labels on those rectifiers? Have you checked that they can handle 2A of current?
Also, what diodes are you using?
I didn't check voltage before this because i was afraid i would burn the ic with 28v at the inputHow much of a Voltage drop is it comparing to original wiring?
I didn't put another diode it's working good on 6 diodesDid you put another diode? How much are you getting out now? Is it working?
