Hello all,
As many of you are having problems with the same diy kit, im having the same problems.
Im using a 24v 3 Am AC as input.
From the troubleshooting thread that i read, non of the measurments are correct with my kit.
1st indication is that LED is constantly active.
With 10k pontesiometers i can change output voltage but anti clock wise is 20v and clockwise 1.1
When i try to use output to a lamp 12v nothing happens.
I have triple checked material installed and its correct. also i have even change some of the part with new one, because there was wrong.
Point A : is 33.5V instead of 32.5V
Point B: instead of -5.6v i have 326mV
Point C: is 24V Correct
Can somebody help to fix this problem.
