Hello everyone,
Like in a thread just below this one started by SpeedMaster57, I'm also having a problem with my DIY kit. I'm feeding it with a 24V 2A AC-AC transformer.
After assembling everything, I'm reading 0,13V on the output, LED stays off and turning pots doesn't do anything.
I can measure following values:
- On Fan Output I'm getting 24V as I should
- Across rectifying diodes D1 and D2 (I think?) I'm getting 17.2V
- Across rectifying diodes D3 and D4 (I think?) I'm getting 16.3V
- Across C1 Cap I'm reading 36.1V
- Across C2 Cap I'm reading 23.1V
- Across C3 Cap I'm reading 7.6V
- Across C7 I'm getting no voltage
- Across D11 I'm getting no voltage
- Across D7 I'm getting 1.46V
- Across D8 I'm getting no voltage
- Across D6 I'm getting 3.24V
- Across D5 I'm getting 2.06V (I'm really not sure, but somehow I get the feeling that this diode should be turned other way around, could somebody verify that? I did put it in the circuit as it was labeled on the PCB, but following that diagram, I'm under impression that anode of D6 should be getting on cathode of D5?) I'll put a detailed photo in the thread...
If any other values are necessary, don't hesitate to ask, I'm in my workshop all day today...
