Is sits on a thermostatically controlled heater for the winter.What is going to stop that from freezing also?
Max.
Max.
This is our first year keeping chickens and they free range so their requirements for water seem to fluctuate quite a bit depending on how much time they actually spend in the coop. I could put myself on a better schedule I suppose, but this is more funI have 10 chickens, and I like electronic gadgets, so don't take this the wrong way.
Isn't the amount of water your chickens drink fairly consistent from day to day? And can't you use that information to tell reasonably close to when they are going to run out of water? I know, for example that my little flock will drink not more than a gallon of water per day on even the very hottest days, so I know that I need to refill the five gallon dispenser every four days and still have a significant safety margin.
Of course, if you want a remote monitor with rf notification just because, that's good, too.
Here is the finished product - thanks again to all who helped, especially MikeML:I'll be installing MikeML's circuit design today and will let you all know how it goesThanks so much for all of the help!
My next project will be a remote monitor for the levels of water and food in the coop if you're interested in helping me tackle another one![]()
The DC gear motor that I got from surpluscenter.com was only $14 and puts out 8in.- lbs. of torque, plenty for this application! A counterweight would be superfluous in my case, but is a good idea in generalThe chicken coop door comes up quite a bit, here and other forums.
Comment: Counterweight the door.
Assuming you have two timers, two dc power supplies, two spst 12Vdc relays, with two normally-closed limit switches, this is about as simple as I can make it:
Hi,I have 10 chickens, and I like electronic gadgets, so don't take this the wrong way.
Isn't the amount of water your chickens drink fairly consistent from day to day? And can't you use that information to tell reasonably close to when they are going to run out of water? I know, for example that my little flock will drink not more than a gallon of water per day on even the very hottest days, so I know that I need to refill the five gallon dispenser every four days and still have a significant safety margin. Besides, don't you go to coop every day anyway? for eggs or companionship or something?
These are great points and this is currently what I am thinking about now that I have a functional system againHello again,
A couple issues come up here.
First, the relay coil reverse diodes. There should be one on each coil. This prevents higher voltage spikes from arcing the contacts that turn the relay on and off which can cause contact welding and thus failure. That brings us to the next issue.
Second, failure mode analysis. How can the system fail, and what are the consequences.
If one of the limit switches fails closed then the door motor runs continuously and runs the battery down, or burns out the motor, or wrecks the door mechanism. If if fails open then the door is stuck open or closed forever.
This means there should be some secondary backup system to check to make sure the first system works ok, and possibly a secondary mechanism for example for the door so that it is only allowed a certain amount of time to run, such as 30 seconds or whatever is appropriate. In case of any failure detection an alarm should sound if it is a critical error detected, or a lamp (LED) lit up if non critical. If the life of the animals is threatened by a failure obviously that needs immediate attention.
At the least maybe a second set of switches to detect if the first set did not function, and maybe wired so that they both have to work right in order to operate the door or something like that.
Magnetic switches have the habit of getting stuck closed sometimes even when the magnet is pulled away from the switch. They only work for so many cycles and then start to fail. Some are better than others of course.
They can also fail to close after a certain age.
So the idea is to try to think of all the ways the system can fail and try to build in a secondary method to make sure everything is always working right. This can be very important for livestock.
What happens to us sometimes is that when we build an automatic system it usually works for a long time and we get so used to it working that we forget that it can stop working at any time. Thus we end up relying on the system and forgetting to check it because it works so darn well for years. Then one day it fails and we dont know it because we got so used to it working so well for so very long and so did not bother to check it manually.
Don't overlook the fact that the limit switch doesn't have to be at the very bottom of the door. Just be sure that it and the actuator at the same height when the door is in position. My door uses two mechanical switches attached to one of the studs; there is only a single actuator attached to the door.I think that it does need to be something magnetic, especially for the bottom of the door because coop bedding could easily interfere with a physical switch.
By the way, my next project is to use a Wi-Fi module to report the temperature inside the coop to Thingspeak, and have Thingspeak send me a tweet when it gets too hot or too cold.
They look like the standard switches used in security systems, although I think they also come in a more rugged housings.The magnetic door sensor switches that I used for limit switches are these: http://www.amazon.com/gp/product/B0009SUF08?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00 and honestly, they seem pretty crappy. Is there something better/more robust that anyone can recommend? I think that it does need to be something magnetic, especially for the bottom of the door because coop bedding could easily interfere with a physical switch.
