Checking the +B and -B voltages in a Solid State audio amp
programmer6502
Joined Feb 1, 2014
132
I'm working on a Solid State audio amp and want to know if I'm checking the +B and -B voltages correctly with my multimeter. What I have here are both of these voltages outputting from a bridge rectifier and I'm putting my positive probe on +B and the negative on -B, which results in FAR off tolerance voltages considering the amp still functions (with a couple intermittent issues). Since B- is a negative voltage (opposite of the B+ voltage), am I supposed to treat it as an independent voltage and ground to the chassis/common instead when checking either +B or -B? I just want to be sure.
Thanks
#12
Umm...yes.
Still, I fear that if you don't already know this, you are in danger of both failing at the job and getting hurt.
Proceed with caution!
programmer6502
Joined Feb 1, 2014
132
Absolutely man! The reason I came here is cause I don't feel like taking a fatal shock or blowing the amp up! So is that a yes for chassis grounding when checking those?
And here's the power supply portion of the amp and I marked where those voltages output. I can't provide more than this:
#12
Look to the, "split" capacitors to find your, "common" points. For instance, the line marked, "J".
From there, you can Ohm to chassis to discover if the designer connected the chassis as a big common terminal.
If your measurements suddenly turn to garbage as you delve deeper into the circuitry, there is more than one common point in the amplifier. It is sometimes convenient to let a transformer winding "float" for certain kinds of circuits. Therefore, some of your voltages will behave exactly as you expect and some of them will wander all over the place, depending on the power output level at that moment. If that happens, the only choice left is to examine and learn the schematic.
12,155
Hard to see some of the reference designators, but it looks like D16, 17, 18, and 19 form a full wave center-tapped bridge driving two big caps that are an unregulated bulk power source for the speaker amps. The system is relying on the power supply rejection capabilities of the amps to keep ripple out of the audio. Each of these power rails should be measured with respect to system ground, which is either speaker's - terminal connector. With the volume all the way down, there should be the same voltage on each rail and very little ripple.
programmer6502
Joined Feb 1, 2014
132
Perfect, that answers my question. And I recently checked to see if the chassis is connected to that same common shared by the capacitors and it is.
Thanks man
programmer6502
Joined Feb 1, 2014
132
I love watching you guys work! You have everything figured out in seconds lol!
12,155
After Lee Trevino made a hole-in-one during a tournament, an interviewer congratulated him on his "lucky" shot. Lee got fake-incensed and said Luck?!? I've been practicing that shot for 40 years!
programmer6502
Joined Feb 1, 2014
132
All voltages on the power supply look decent, nothing exploded and I'm alive to report. ;) This narrows down the problems considerably.
Thanks all once again, this is a great forum!
programmer6502
Joined Feb 1, 2014
132
By the way, I'm getting an intermittent 120hz hum in the speakers on all channels. Back when I was using it, if you slammed the top of the amp cover with your fist the hum would stop for a random amount of time, then it would usually come back meaning that there's most likely cold solder joint(s) somewhere. I know that a 60hz hum/buzz from household AC changes to 120hz when rectified, which would be a fault in the power supply section. The hum is effected with the volume control (frequency stays the same), so I think that means the fault is before that stage. Do you guys know what the most common faults are when this happens? I'm going to continue diagnosing myself, and am looking into building a slick single tracer but I thought it wouldn't hurt to ask you guys real quick since I have this up!
Here's exactly what it sounds like:
Thanks
#12
As a really serious pro, I wouldn't bother with a signal injector or a signal tracer. The hum is doing that for you (if you know how to use it to your advantage). You will go looking for bad solder joints and diseased filter capacitors. Don't forget the input jacks. It might be a grounding fault starting right at the input to the first stage.
Delete that last sentence. I thought you said the volume control was in charge of amplitude. If same for all inputs, then input jacks are not the problem.
12,155
Keep working the clues. If it is in all channels, then it probably is in a circuit that all channels go through, something after the selector but before the volume control - like the tone controls. If you have the complete schematic, trace the tone circuits power backwards. Maybe there are local decoupling caps that have come loose, of one of the bulk filter caps has a failing solder joint while the other one is ok. Look for hum sources that are out of balance.
programmer6502
Joined Feb 1, 2014
132
I think the same and have it narrowed down pretty good. The amp is actually a Kenwood from the 80's and is all digital in the front with a built in equalizer and spectrum analyzer that adjusts everything. Not one potentiometer to be found, all tactile buttons! But with the service manual I have, that isn't a problem.
My biggest fear is if the two +B and -B filter caps are going out. They're massive Elna 7500uf 71v capacitors and I can't even find any that would replace them if that was the case! But I'm not jumping to conclusions, there are other things it could be. I'm not sure if Elna is a good brand, but the amp seems to have good Japanese branded caps all around. Only testing and examination will tell!
I don't think this is anything to do with the humming, but I found two shorted ceramic series resistors (one for each channel between power transistors) in the final stage. Will have to get those replaced as well.
