check this transistor amplifier circuit
Dan Aronin
Joined Dec 14, 2018
37
I'm new to electric amplifier circuits and I'm trying to make one that will produce a 1A output (1A@3V) to a load from a 1mA input.
Here is what I thought of:
Will this circuit work or how should I properly design this?
Dodgydave
Joined Jun 22, 2012
11,395
The Tip120 is a Darlington with 1.4VB/E drop with an hfe of 1000,
So 3.7v-1.4v = 2.3V with a 1.2K base resistor is 1.9mA base current x hfe is 1.9A Collector current.
ericgibbs
Joined Jan 29, 2010
21,554
hi Dan,
You cannot increase the current by using a transistor connected in that way, you need 3V 1A power source.
The top of the load is connected to 0V!
E
ericgibbs
Joined Jan 29, 2010
21,554
hi,
No current.!
A transistor cannot generate a current.
It can only control the current that is available from an external power supply.
E
38,746
If you only have 1mA at the input, then a logic-level N-MOSFET (designed for operation with a 3.3V input with a Vth max<2V) might be a better choice.
MOSFETs require essentially no input current.
Dan Aronin
Joined Dec 14, 2018
37
Yes but as far as I understand a transistor must have additional power source (example: collector), hence 1A will still flow from the power source (lipo 3.7v@500mAh) as mentioned in #3
I 'm looking for a solution to avoid that.
kubeek
Joined Sep 20, 2005
5,796
There is no free lunch, and there is no solution around that. You cannot create power from nothing, so if you want 3V*1A, which is 3W, then you have to provide the 3W at the input. From a battery, power supply or whatever else.
BobTPH
Joined Jun 5, 2013
11,634
You can get 1A and 3V from a 1mA input, but the input voltage must be 3000V plus another 10 or 20% for losses.
You can also get 1A at 3V for 1 second from a 1mA 3V input if you let it charge a capacitor for 1000 seconds plus extra to cover losses.
What are you actually trying to do?
Bob
