What is the simplest way to check transistor flow with a multimeter?
Julianna
Joined Nov 4, 2023
Set your multimeter to diode mode. This activates a small forward bias voltage, mimicking the typical operating condition of a transistor.
28,601
Using the diode mode setting of a digital multimeter is able to measure the base-emitter junction voltage of a bipolar transistor. It may alert you to a failed transistor but it does not verify a useful transistor.
