Chat GPT ..#2
biferi
Joined Apr 14, 2017
531
I go to use Chat GPT now and after it gives a reply you can click on the Speaker Icon under it and it will read the reply.
I asked it if it can read in a Female Australian Accent and the reply say yes it can.
Then it reads with the same Male Voice.
How do I get it to change?
Alec_t
Joined Sep 17, 2013
15,152
I'm happy to be corrected, but I doubt you can, unless there is an option to use a different locale. ChatGPT is quite capable of generating fiction. Also, just because it says it can do something doesn't necessarily mean it will do it.
WBahn
Joined Mar 31, 2012
33,108
Or that it actually can do it -- as you noted, it is quite capable of generating fiction.
Liam_Lucas
Joined Apr 23, 2024
To change the voice, specify the desired accent in your request. For instance, you can say "can you read this in a female australian accent?"
