How will current change automatically can you please explain12V sla batteries are charged at 13.8V constant voltage, the current will alter automatically as the battery is charging.
The battery draws what current it needs , a 1.3aH sla wont draw more than 600mA on charging.How will current change automatically can you please explain
I am using a 17V 5W solar panel in this case so i think the current should not exceed 0.29AThat's a really-really small Lead-Acid-Battery.
If you have a Big-Panel, You could overheat the Battery, and eventually damage it.
Generally, You can charge a Lead-Acid-Battery at its rated Output,
in this case, 1.3-Amps.
Will your Panel generate more Current than that ?
If You routinely discharge the Battery to a very low State-of-Charge,
it may pull too much Current, that is, if your Panel can deliver more than 1.3-Amps.
To be completely safe, use the following Circuit,
but change the Current-Limiting Resistor so that it will limit
the maximum Charging Current to less than 1-Amp. .............................
So what you are saying is i dont need to mind the current voltage should be the only consideration. Am I right?I am using a 17V 5W solar panel in this case so i think the current should not exceed 0.29A
Do you know the output voltage of fully charged 12V lead acid batteryYes you only need to manage the Voltage , the battery will set the current as it is charging, a bad battery will draw the maximum current, and will probably trip the chargers current limit.
If you're using a Solar panel i would use a buck converter or mosfet opamp to keep the voltage at 13.8V,. a linear regulator will waste heat.
Other members here have some good ideas too, but to know the max charging current and stuff like that you have to get that from the manufacturer's data sheet for that very battery.I have a lead acid battery of 12V 1.3Ah battery used for a solar charger circuit. I need to know the charging current and voltage for it. if it is connected to the panel always.
Invariably 0.2C in the datasheet. (Though some battery manufacturers have told me that they will withstand the same charge current as the maximum discharge current, provided that they are kept below the gassing voltage and recombination is not required)Other members here have some good ideas too, but to know the max charging current and stuff like that you have to get that from the manufacturer's data sheet for that very battery.
Yes, if it is designed for float, not if it is designed for cyclic use.The float voltage is made for keeping the battery charged when it is not being used. It is meant to compensate for the self discharge of the battery. The self discharge is the discharge when the battery is not connected to any load or to any charger. It means the battery discharges over time and because of this the battery is often kept on float charge. it keeps a little current going into the battery all the time.
If you keep it connected to a solar panel indefinitely the key issue is what current does it deliver during that time. If it is a small current similar to what we would see in float charge, then it is ok but if it is too high it will overcharge the battery and ruin it.
Yes, constant current bulk charge (0.2C) followed by 14.7V absorption charge, followed by 13.65V float charge, as I said.Modern chargers have at least 3 stages you should probably look into that.
Float charge is meant to replenish the self discharge, it does not need to be constant. In fact, i have found that it is better to charge at a lowish charge rate for some time and then let it 'rest' for some other time, then repeat. So a solar charge could be used in that way.Invariably 0.2C in the datasheet. (Though some battery manufacturers have told me that they will withstand the same charge current as the maximum discharge current, provided that they are kept below the gassing voltage and recombination is not required)
Batteries designed for float use have a specified life on float, either 5 years, 10 years etc. They are meant for emergency power usage, they are only intended to be discharged very infrequently.
Batteries designed for cyclic use will dry out and have a very short life kept on float charge. They will last rather longer if allowed to self-discharge then once in a while topped up with a charge to 14.7V
A solar panel cannot keep a battery on float charge because the sun doesn't shine at night. During the night the battery will discharge; when the solar power returns, the battery should be recharged to 14.7V. Recharging it only to the float voltage will mean that it is never fully charged and will shorten its life.
The float voltage should also be temperature compensated by -3mV/°C/cell
1 cell lithium battery charging protection | Analog & Mixed-Signal Design | 5 | |
| B | Sega GameGear Charging Pack Help Needed! | Technical Repair | 6 | |
Question about charging 12v battery | Power Electronics | 14 | |
| J | Super Capacitor Charging | General Electronics Chat | 32 | |
| J | LiPO Power Charging and Power Supply | General Electronics Chat | 4 |
