Hi, I have four battery powered roller shades. Each has an 8.4v 1000ma DC charger.
The battery life is not very good and hooking up the DC chargers is a hassle. So is trying to raise or lower the blinds only to find out the batteries are dead.
I was thinking of hard wiring them by running a single DC wire to the top of one window, then splitting it into four lines, each with a barrel connector to connect to the blinds.
I have a couple of questions about this:
1. Do I need to worry about current being drawn out of one shade and going into another, or other issues with running them off one split cable? Is there a simple circuit I can use to eliminate any issues?
2. Would it be OK to have them permanently charging with DC, or would it be better to put the chargers on a timer so they only provide current for a few hours every few weeks (just enough to keep the batteries always charged)?
3. How should I approach the DC amperage? Should I measure the actual amp draw of the blinds, get a 4 amp charger, or use resistors to limit the draw of each to 250ma and use one of the current chargers?
Thanks
Thanks
