Charging circuit
SWB95
Joined Jul 21, 2015
4
Can anyone point me in the right direction?
I want to set up a charging circuit for a 9 volt battery which will charge once the battery level is 5v and stop when it reaches around 9.
I want to run the charging circuit off an alternator which will only come on when the battery needs charging and once the battery is fully charged the alternator will switch off.
The battery is running a small circuit which can function from 5 - 12v. Hence only charging once it drops to 5v
Is this possible? and does anyone have any examples or circuits.
Thanks
ErnieM
Joined Apr 24, 2011
8,415
To beat#12's reply you will kill your battery doing that, no matter what the battery is supplying.
Are you intending to build your own charger (not recommended) or adapt something off the shelf?
