Charging Circuit from Cheap Flashlight - How does it work?
Status
Not open for further replies.
electroram
Joined Jan 1, 2017
14
I broke apart a cheap flashlight to look at how it works. It is a rechargeable flashlight you can just stick into a wall supply, but you're supposed to do this only when the flashlight is in "OFF" state. By mistake it was being charged in "ON" state and seemed to stop working, hence the breaking.
I have drawn the circuit of the flashlight when it's charging:
Can you please explain how it is working? There doesn't seem to be stepping down, rectification, so how does it convert the AC to DC and charge the battery?
The battery is pretty big in size. Also, R1 in the circuit is quarter watt, 390 kohm, R2 is quarter watt, 300 ohm. The capacitor C1 is rectangular in shape, not electrolytic. Thank you.
Dodgydave
Joined Jun 22, 2012
11,395
Why would a designer choose this strategy? I mean, why not just use a different charger voltage in the first place?
Dunno, maybe the TS has drawn it wrong.... Seems stupid to charge a non electrolytic cap up on one cycle and do nowt with it, it's too small to be used as a Voltage doubler method ???
ian field
Joined Oct 27, 2012
6,536
If you posted that circuit as a project; the moderators would close the thread.
There's no mains isolation, I'm guessing you wouldn't find a wattless dropper downstream of a step down transformer.................
Dodgydave
Joined Jun 22, 2012
11,395
It uses One Half of a sinewave voltage, so uses one Diode instead of using a Full wave bridge rectifier, its a cheaper method to drop Half of the Voltage.
electroram
Joined Jan 1, 2017
14
It's not a project. I would've imagined using a transformer, rectifier and regulator before charging a battery. I saw this circuit inside of a REALLY REALLY shabby flashlight, the "Made in You-Know-Where" kind, no disrespect. So, I don't know if this is a scam circuit that isn't meant to work, or it's some workable circuit that just overlooks aspects for smaller budgets.
Then what does the cap, D2 and D4 do? Thank you.
So the cap is useless? Is the "voltage doubler" method used for charging batteries?
Thank you for your response. What's a charger voltage?
electroram
Joined Jan 1, 2017
14
Good question, unless you have drawn it wrong, i would say nothing,, although it looks like a simple voltage doubler, but i assume your circuit is powered by a transformer??
Can you post pictures of it?
There was no transformer inside the flashlight. I will post detailed pictures of it. It may take a while. Please be patient. Thanks.
wayneh
Joined Sep 9, 2010
18,150
Huh. I assumed there was a step-down transformer. In the simulation, you can eliminate the capacitor and it doesn't matter much. So I'm still confused about this. It uses 4 diodes, why not just make a bridge?
electroram
Joined Jan 1, 2017
14
The red and black leads go to a single LED. This is connected in series with the battery, a half watt, 1 ohm resistor and switch.
The two green leads go to two round prongs that can be inserted into the wall supply, this is the "AC in" in my drawing of the charging circuit.
The green and black leads go to an array of smaller light sources. Again, this is in series with the battery, the half watt 1 ohm resistor and switch. The switch has 3 modes, "SINGLE LIGHT", "OFF", "LIGHT ARRAY". The yellow and black leads go to the battery.
bertus
Joined Apr 5, 2008
22,999
A wattless voltage dropper is a technique used in cheap stuff like your led tourch.
The circuit is not allowed here on this forum out of safety.
The User Agreement has a list of restricted topics.
Bertus
Status
