Charging a surface Pro from an external Battery-pack
ElectronVolt
Joined Jul 5, 2020
I hope i will find some help here.
what i am trying to do is to charge my surface pro 2017 from a external Li-Ion battery pack instead of the AC charger.
the rated values from the AC charger of my surface are 15V , 2,58A
i am using 12 x ( 18650 cells ) in 3 series and 4 parallel config so the output of the pack is 10,8 - 12.6 V (Max discharge current 5A per cell ; 20A for the pack ).
I am using a 3s BMS for the pack and, a buck-converter (Max current 4A) to boosted the 10,8- 12,6V to constant 15V.
the good news is it works ! the bad news it charges too slow !
when i measured the charging current i found that it is significantly less than the measured charging current when using the AC charger!
some mesurments results :
when charging using the pack -----------> Iboost ~ 0.8 A @15V
when charging using the AC Charger ---> ICharger ~ 2.3 A @15V
and now my actual question is:
i don't understand why the surface drowse different current if the Voltage is the same (ohms low !) !?
how could i possibly solve this problem !?
ElectronVolt
Joined Jul 5, 2020
I wonder if the surface talks to its charger before switching to a high charge rate?
i don't really know how to check that the best way ! but i don't have an oscilloscope (if absolutely necessary i could get access to one).
but i have one of the AC chargers open and i can see the main ic's
i attached a photo that shows the main ic's.
the main ic's datasheets:
1- https://www.ti.com/lit/ds/symlink/tps54226.pdf?ts=1594022706845&ref_url=https%3A%2F%2Fwww.ti.com%2Fproduct%2FTPS54226
2- http://dalincom.ru/datasheet/OB2269.pdf
i am not sure if a communication could be achieved with one of those ic's !?
Irving
Joined Jan 30, 2016
5,146
On the face of it, no, there no comms. Intriguing that there are two smps chips though, can you do a pic of the top side please.
