Charging a car 12v battery
john2k
Joined Nov 14, 2019
219
I have a completely flat car battery as I've been unable to drive for nearly 2 months. If I disconnect the battery and bring it indoors is it possible to charge it with a AC to DC power adapter? I have one of the following power supplies that I use to test 12v things indoors https://www.ebay.co.uk/itm/190882903153
Just wondering if instead of powering something with it, will it charge the battery if I was to put the output of that onto the battery or is that a disaster? Lol just a thought lol
jpanhalt
Joined Jan 18, 2008
11,087
Are you within walking distance of a service station?
If your battery has been dead flat for 2 months, there is a good possibility that it is ruined. Charging it might get you started, but going somewhere in that car could get you stranded. The engine may even die while on the road.
That is why I suggest a service station. There, they can test whether the battery is ruined.
Ian0
Joined Aug 7, 2020
13,252
The first stage of charging a lead-acid is constant current, so a constant-voltage power supply would either be overloaded, shut down, or running at its current limit, any of which it might not appreciate!
If the Battery voltage was <10.8V before you disconnected it, it is probably dead. If more than that, but unable to turn over the engine it will probably recharge.
john2k
Joined Nov 14, 2019
219
Thanks for the replies. The battery is covered by a 5 year warranty and I spoke to the shop I bought it from said it's completely dead can you charge it for me and they said it's under warranty do just bring it we will give you a new one
Tonyr1084
Joined Sep 24, 2015
9,744
Check out THIS thread. Synopsis: Wife left lights on for two days. Battery absolutely dead. Battery was 3 years old and I was concerned with whether it would come back or not. It did. But it's likely not going to last as long as it would have had it not been so completely drained.
Your battery - sat for two years with no charge. Probably fatal.
dl324
Joined Mar 30, 2015
18,454
I'd take them up on it unless they're going to prorate for the replacement. In that case, have them test the battery to make sure it's bad.
Around here, I think they only give free replacements if the battery fails within the first year. After that, they give a prorated price for the replacement.
Audioguru again
Joined Oct 21, 2019
6,826
If the car was not driven for only 2 months which killed the battery then either the battery is no good or lights or something in the car was left turned on.
Ian0
Joined Aug 7, 2020
13,252
On a modern car three weeks is long enough for it not to start, due to the amount of electronics that runs continuously. (Found that out during lockdown)
But with all the fancy battery management systems cars have these days, why does it not disconnect the battery completely below 10.8V?
Tonyr1084
Joined Sep 24, 2015
9,744
My "EverStart" Walmart battery has a 5 year warranty. 3 year 100% replacement. Meaning if I can prove it's less than 3 years old and bad I can replace it for free. However, this battery (in my wife's car) was already warranty replaced once.
Even battery monitoring equipment uses some power. Had Lithium Ion batteries go bad because of the continuous monitoring.
