how can i charge it using a low cost regulated power supply.
there is limited resources about this topic in net.
there is no charger provided.
1. should i connect resistor in series with battery to limit the current supplied to battery? what is the value of resistor
2. what must be the polarity of the battery with reference to dc supply
3. what must be the voltage value setting of the dc supply
4. how long will i charge it
5. should the temperature of battery rise as i charge it ?
any other insights given the limited resources.thanks in advance
