Hi all,
I'm using an inverter-charger unit as a UPS for a a hydraulic pump (single phase induction motor), one of these:
(https://zlpower.en.made-in-china.co...brid-Charger-Power-Inverter-Lw1000-6000W.html)
It works well enough, when the mains a.c. drops out it switches over to inverter output seamlessly but when the mains comes back on and the unit switches back into charging mode rather than inverter mode, after a second or so the circuit breaker trips. I connected up a current probe and got this:
A current spike of about 320 A. Understandably the voltage wobbles a bit too. It only seems to happen when switching back to a.c. mains from battery. I have a couple of theories on what is happening but wanted to ask here if anyone has seen this before or has any knowledge of what might be going on to cause this?
Many thanks
Dean
Many thanks
Dean
