charge pump help need
hertz.12
Joined Apr 25, 2015
41
hi
i want step up voltage from 3.3v to 6v...so i made charge pump but i put 2222 transistor instead of diode...now every thing work fine and i have 6.1 volt ..no problem with circuit...but i am afraid that the transistor may be damage because the "Emitter-Base Breakdown Voltage = 5v" i am really don't understand what Emitter-Base Breakdown Voltage are???
here is my circuit
33,171
Emitter-base breakdown voltage is exactly what it says. If the emitter-base voltage exceeds 5 V, then it may break down and start conducting current.
hertz.12
Joined Apr 25, 2015
41
so i have to put Schottky diode between the transistor and the cap to protect the Emitter from exceeds 5 V
sure?
it works fine now and nothing happen to 2n2222
thanks
jjw
Joined Dec 24, 2013
823
I don't understand how the circuit could work, the base is floating and the transistor never conducts.
Is the diagram correct ?
What is the 20Hz voltage on the base ?
Edit: Forget the former sentence about the base, but this circuit won't charge or pump :)
jjw
Joined Dec 24, 2013
823
To double the voltage, Q1 must be a PNP transistor, emitter to +3.3V, from collector a diode to another capacitor, the base voltage pulsing from 0 to 3.3V.
