How much charge is in the capacitor a long time after the switch is closed?
B Thread Starter bobbyjoe6969 Joined Apr 28, 2018 1 Apr 28, 2018 #1 How much charge is in the capacitor a long time after the switch is closed?
dl324 Joined Mar 30, 2015 18,453 Apr 28, 2018 #2 Welcome to AAC! For homework, you need to show your work.
WBahn Joined Mar 31, 2012 33,109 Apr 29, 2018 #3 If you don't know enough to show some work, then explain what you know about the following questions: What does it mean for it to be "a long time" after the switch has closed? What determines that it's been long enough? How much current is flowing into the capacitor once this "long time" has passed? Answer those (or show your best attempt) and we'll proceed from there.
danadak Joined Mar 10, 2018 4,057 Apr 29, 2018 #4 Q = C x V What is the final value of V (epsilon in this case) ? Regards, Dana. Last edited: Apr 29, 2018
WBahn Joined Mar 31, 2012 33,109 Apr 29, 2018 #5 danadak said: Q = C x V What is the final value of V (epsilon in this case) ? Regards, Dana. Click to expand... By "epsilon" do you mean "E" (the battery voltage, written as a script uppercase E)? If so, then look again.
danadak Joined Mar 10, 2018 4,057 Apr 29, 2018 #6 Looked like - https://en.wikipedia.org/wiki/Epsilon Regards, Dana.
WBahn Joined Mar 31, 2012 33,109 Apr 29, 2018 #7 A capital E, either print or script, is often used for a voltage (coming from "electromotive force").
wayneh Joined Sep 9, 2010 18,136 Apr 29, 2018 #8 danadak said: Looked like - https://en.wikipedia.org/wiki/Epsilon Regards, Dana. Click to expand... Yup, and look again as @WBahn has clued. The steady state voltage on C is not E.
