Changing Sources
Sajan Gurung
Joined Dec 20, 2018
33
While changing sources what are the things i need to consider. Like in the question if i need to change 10A current source in parrallel with 10 ohm to voltage source how can i change it. And also 20A in parallel with 20 ohm resistor.
Sajan Gurung
Joined Dec 20, 2018
33
The voltage source polarity will be determined by the current source direction.
Yor equivalent circuit is wrong. Why the 10-ohm resistor is not in series with the 100V voltage source ?
Oh that was a silly mistake, yea i know i calculated voltage using 10 ohm but wrote 20 ohm, but any way thats how its changed right?
