Changing Scale on voltage divider.
ericgibbs
Joined Jan 29, 2010
21,628
hi Pepe,
If you are using this project only as laser beam break detection barrier, the simple Digital detector you have built should be OK for raising a MCU Interrupt.
What is the laser barrier being used for.? ie: what is causing the laser beam break.?
E
Pepe333
Joined Feb 12, 2018
86
The photodiode will work in 2 ways:
-Analog for detecting littles changes in light (detect lightnings for example)
-Digital for detecting fast moving objects breaking the laser barrier.
In digital mode I need to detect an air gun bullet. It travels at 1000f/s aprox. So the bullet moves 1mm every 3,3us. The bullet is 5mm diameter. We have 5*3,3 = 16,5us to detect it (this is the time the bullet breaks the barrier).
I'm going to start to test if the previous circuit works well. :)
