I’ve seen rocket switches that switches to different poles,
I assume you are meaning a "rocker" switch? Never heard of a rocket switch. Getting the terminology correct helps when searching for things. Pretty sure I have seen what you seem to be describing. Like a rotary switch but a push button advances the poles. I just can't recall who made them.Like a normally open center off rocket switch
It appears the OP wants OFF each function on release?. Like a rotary switch but a push button advances the poles. I just can't recall who made them.
Ron
9VWhat kind of current/voltage is it switching?
It’s not a necessity, but it’s an advantage.It appears the OP wants OFF each function on release?
