Change switching to non-switching adapter?
basslover
Joined Jul 31, 2017
6
Thanks for your reply crutschow. I understand switching adapters produce a lot of line noise and I'm trying to minimize line noise.
basslover
Joined Jul 31, 2017
6
But is it causing noise in your stereo system?
When I shut the device off, which is an equalizer for the sub, the overall musical sound becomes noticeably more detailed and you can hear more into the music. So I'd like to see if the negative effect is avoided with a non-switching power supply.
38,690
Then you should be able to power it with a non-switching supply with the same voltage and minimum current rating (the current rating can be higher but not the voltage).
basslover
Joined Jul 31, 2017
6
Thanks. I haven't been able to find any adapters that are non-switching. Do they still make them?
basslover
Joined Jul 31, 2017
6
Are you up to doing that?
No, I'm just a beginner learning what I need to know about power and circuits to optimize music systems. I was actually just told by the authorized repair center for the stereo component in question, that it wasn't designed to receive power from a non-switching adapter. I'm such a newbie, that I don't even know if that makes sense, because I assumed the current flowing into the component would be identical, whether the adapter was of a switching or of a non-switching kind.
38,690
It makes little sense to me either.
I think the repair center was blowing smoke.
As long as the amp gets the rated voltage and current it shouldn't care where it comes from,
basslover
Joined Jul 31, 2017
6
The component isn't an amp, it's an equalizer for the subwoofer, but I think your analysis would apply to an equalizer as well, correct?
Thanks for your continuing help!
35,030
Is there any power information printed on the backside of the equalizer or the power adapter?
