change RTD with thermocouple
mohsin_rauma
Joined Sep 4, 2023
in given circuit R2 is the RTD (50ohm at ambient temp and 223.7 ohm at 450 degrees(maximum temp) at maximum temp the o/p is 3.583 volts and Vout gives to Arduino nano A0pin i want to change RTD with Thermocouple because that type of heater element is not available the o/p of Thermocouple is 5mV to 20mV what the change in given circuit will work......?
ericgibbs
Joined Jan 29, 2010
21,499
hi m,
That RTD circuit is totally unsuitable for a Thermocouple, also the LM358 OPA.
To increase the 5mV through 20mV to say 3.5Vout requires a Gain of ~175.
Do you have a part number or type name of the thermocouple that is available?
E
