Hello
I build circuit in Ltspice but need to put special type of transistor instead of existing , so is there a fast way to change all transistor ? or I must change each of them separately ?
thanks
I know two ways.
The First: Open the file with extension "asc" text editor (for instance Note pad). Change all old name on new name (in editor there is group (wholesale) change).
The Second: use the command AKO. For instance .model oldname ako: newname.
I find a simple osc circuit that use IBM 65 nm .lib file, and I want to use 90 nm transistor from another library, so can I change in one place to change all the circuit transistors or I must change all of them manually?
Thanks
