Challenge of OLD TV(Sony KV 2192M3)
R!f@@
Joined Apr 2, 2009
10,014
G2 cap is C852, which is not an electrolytic.
Also C701 and C703 on the neck board.
You can also check R738, R736, R701 and 2.2MΩ VR (the screen pot) on the neck board.
R!f@@
Joined Apr 2, 2009
10,014
A failure of G2 voltage will result in black screen without OSD.
A failure of 200V Video amp voltage will result in white screen with retrace lines for few sec and some times TV goes into protection
ranatungawk
Joined Oct 30, 2008
226
here, one side is white where as the other side is perfect ! can a bad electrolytic caps cause this kind of issue ?
ranatungawk
Joined Oct 30, 2008
226
It did to me.
Hi friend,
I was able to check it today as you have mentioned. however it couldn't be fixed yet. C852, C861, C814, C704, C701, C703 was replaced. and R738, R736, R701 and 2.2MΩ VR were found good.
however C851 couldn't replaced because according to the circuit diagram it's 250V so I brought a 22uf/250V cap but when i checked the PCB it was a 350V cap. so i removed it from the board and check with a tester. I found it's capacitance is correct with low ESR value then it was (reinstalled again). further G2 & G1 voltages were 331 and 28V respectively. pls see the attached pics ....i'll replace the C851 tomorrow. anything else to be checked ?
R!f@@
Joined Apr 2, 2009
10,014
And Disconnect the G1 and connect it to ground (not the pad...just the G1 socket terminal) through a 1KΩ 2 watt
resistor, that should be low enough to keep it at or near zero volts
The tube should stay dark.
Check if the white strip appears or not.
ranatungawk
Joined Oct 30, 2008
226
Does 28V G1 abnormal ? what should be the correct value ?
By the way pls let me get clarified :
resistor
disconnect the neck-socket terminal 5 from the PCB; then sold a 1K/2W resister to the terminal and the other side of the resister should connect to the (-) of the pcb...correct ??? {sorry for my silly questions :)) }
R!f@@
Joined Apr 2, 2009
10,014
Desoder the CRT socket G1 terminal from the PCB and connect the resistor to CRT socket terminal to the board GND
Leave the G1 board pad out of the circuit meaning there should be no connection between board to G1 terminal.
The G1 voltage should be a bit higher. 28V could be nominal
ranatungawk
Joined Oct 30, 2008
226
as far as i know , the G1 voltage is a negative (-) voltage. to test, i put the negative prob of the DMM to the ground and the positive prob to G1 terminal. then it show 28V (positive ) , is the way i tested it correct ?
Thanks for your invaluable help ! i'll update you on findings. You may get a clear idea on the issue with the color pics i have attached today
JoeJester
Joined Apr 26, 2005
4,390
G1 is negative with respect to the cathode. What is the Cathode voltage? If the Cathode was 56 volts and the G1 was 28 volts, it would be negative.
G1 is the control grid.
