Thanks friend, meanwhile can you pls tell me what is the Screen Grid Voltage (G2) Capacitor here ?Replace from Main Board near FBT
C851
C861
C814
Replace on neck board
C704
Replace them and check
here, one side is white where as the other side is perfect ! can a bad electrolytic caps cause this kind of issue ?A failure of G2 voltage will result in black screen without OSD.
A failure of 200V Video amp voltage will result in white screen with retrace lines for few sec and some times TV goes into protection
Hi friend,It did to me.
Yas with a DMM it show 28VConfirm G1 = 28V.
Are you using a DMM ?
Ok i'll check them and i couldn't find R736 -- where is it ?Odd.
Can you check R704 & R705
Sorry ... my bad.Ok i'll check them and i couldn't find R736 -- where is it ?
Does 28V G1 abnormal ? what should be the correct value ?And Disconnect the G1 and connect it to ground (not the pad...just the G1 socket terminal) through a 1KΩ 2 watt
resistor, that should be low enough to keep it at or near zero volts
The tube should stay dark.
Check if the white strip appears or not.
as far as i know , the G1 voltage is a negative (-) voltage. to test, i put the negative prob of the DMM to the ground and the positive prob to G1 terminal. then it show 28V (positive ) , is the way i tested it correct ?Desoder the CRT socket G1 terminal from the PCB and connect the resistor to CRT socket terminal to the board GND
Leave the G1 board pad out of the circuit meaning there should be no connection between board to G1 terminal.
The G1 voltage should be a bit higher. 28V could be nominal
G1 is positive I believe.
