Ceramic Capacitor leakages current of few mA after 3-5 months of device installation-2
josescxavier
Joined Mar 20, 2024
A platter is the sheet of pcb,s that came from the PCB assembler witch had been scored but not separated into single units.
it was use separating then that was causing the damage to the caps.
How do you solve it? We have the exact same problem that you and @pdswd described.
Mod Note:
This thread was split from here.
Please don't hijack other member's threads.
schmitt trigger
Joined Jul 12, 2010
2,058
Have also personally experienced this issue, where fault was with the board depanelization process.
This wasn’t idle speculation, multi-K dollars and many months were spent on a very exhaustive investigation.
The solution was to have the board pre-routed in the areas where higher stresses were found with the aid of strain gages.
josescxavier
Joined Mar 20, 2024
Did you try other capacitor part number to check it also happens with a diferent part number?
