Center tap transformer - Full Bridge
cyndi1014
Joined Dec 29, 2017
May I know is it possible for a circuit to have full bridge in Center Tap Transformer with just a load and a capacitor ?
38,752
If you have a center-tap transformer than why do you want a bridge?
You can use a full-wave rectifier configuration with just two diodes.
Of course you can connect a bridge to the two outside terminals and ignore the center tap if you want a higher rectified voltage.
cyndi1014
Joined Dec 29, 2017
@crutshow Thank you so much for the reply!
May I know if it required 240Vac-18Vac with output of 9V-0V-9V ,
Is the given output 9V is in Vrms, Vdc or Vave form?
