CE Voltage Amplifier - Negative Feedback
elec_eng_55
Joined May 13, 2018
214
I am going to understand this stuff and if it kills me.
I have uploaded a simple CE voltage amplifier schematic as modified by Jony.
I believe the DC gain is 2.7K / 380 ohms = 7.1 and before C3 and R5 are added,
the AC gain is also 7.1. Although the simulation says the AC gain is 4.5.
Once C3 and R5 are added, I believe that the AC gain is 2.7K / [(380 * 9.1) / (380 + 9.1)] = 303.
However, the simulation says that the AC gain is 100.
With this type of negative feedback, is AC gain = Rc / Re//Rfeedback?
I am confused.
David.
Jony130
Joined Feb 17, 2009
5,599
The voltage gain will be equal around
AV = (Rc||RL)/( re + R4||R5) = (2.7kΩ||5.6KΩ) / ( 8.6Ω + 380Ω||9.1Ω) ≈ 104V/V
Where re = 26mV/Ie
And this is a current - series feedback.
Also, notice that now when re << (R4||R5) the re variations in the rhythm of the input signal do not count much now.
elec_eng_55
Joined May 13, 2018
214
Where re = 26mV/Ie
Many thanks, Jony.
David
Jony130
Joined Feb 17, 2009
5,599
C3 ≈ 1/(2 * pi * F1 * R5) ≈ 0.16/(F1 * R5) ≈ 0.16/(10Hz * 9.1Ω) ≈ 1758μF ≈ 2200μF
Or if you want to F1 to be set at 100Hz
C3 ≈ 0.16/(100Hz * 9.1Ω) ≈ 175.8μF ≈ 220μF
In reality C3 see this resistance R5 + (re + (R1||R2)/(β+1) )||R4
elec_eng_55
Joined May 13, 2018
214
Thanks again.
Jony130
Joined Feb 17, 2009
5,599
Next time if you want to know how to find the capacitor value. You simply need to find the circuit time constant.
So, all you need to do is to find the effective (equivalent) resistance seen by the capacitor.
That means you have to consider the circuit as seen from the capacitors side.
For example, C2 will see Rc in series with RL if we ignore the transistor output resistance.
t = C2 * (Rc + RL) and the corner frequency is
Fc = 1/(2 * pi * t) = 1/( 2 * pi * C2*(Rc+RL) )
