CE Amplifier Output Problem
ericgibbs
Joined Jan 29, 2010
21,439
hi,
OK.:)
Look very carefully at the form factor of the output sine wave, what do you observe.?
E
BTW: the Form Factor is the 'purity' of sine wave.
ericgibbs
Joined Jan 29, 2010
21,439
hi,
Right click in the Plot area.
On the Pop up menu, select View
Select FFT [Fast Fourier Transform]
Use the Default settings
Click OK.
Look at the Harmonics in the FFT plot.
E
elec_eng_55
Joined May 13, 2018
214
hi,
OK.:)
E
Hi Eric:
The upper and lower peaks have a different magnitude and the width of the upper and lower portion of the cycle is different. Is that what you mean by Form Factor?
Jony130
Joined Feb 17, 2009
5,598
You didn't properly set the DC quiescent current (q-point). You base DC voltage should be in the range of about 1V to 2V (Vb = Ve + 0.7V).
But in your circuit you have 10.7V at the base terminal. And the collector voltage should be set around 0.5Vcc ( around 7.5V in your circuit).
Also, your circuit has a very nonlinear voltage gain.
The voltage gain is a signal level dependent.
Av = gm * Rc||RL ≈ 40*Ic * Rc||RL.
When the input signal swings positive so that the collector current increases, the voltage gain also increase his value. And for negative input signal swings the collector current drops. So the gain decrease his value. As you can see the voltage gain of this CE amplifier was changing when the output signal has swinging. This represents a high level of distortion.
Try this circuit
Maybe this post help you set the proper operation point
https://forum.allaboutcircuits.com/threads/common-emitter-max-current-ic.71069/#post-494633
34,807
I cannot open a .asc file. I presume it is a file from a simulator program.
Is the output AC coupled? If it is, then the average value must be 0V.
If the peak positive value is not the same as the peak negative value, then the wave shape is not symmetrical about 0V. This would indicate distortion in a sine wave signal.
Audioguru
Joined Dec 20, 2007
11,248
Your transistor has no negative feedback to reduce its extreme distortion. A transistor without negative feedback is non-linear (reduced voltage gain) when approaching cutoff (the top of the output waveform).
I biased the base better, reduced the value of the emitter resistor, and increased the values of the collector and load resistors.
Then I added another emitter resistor to add negative feedback that reduces the gain and reduces the distortion.
Bordodynov
Joined May 20, 2015
3,431
Hi.
I do not mind what you wrote, but I do not like that there are different load resistance in your three amplifiers.
Why do not you use Fourier analysis - ".Four".If you did, your remark about distortions would not be just words.
Audioguru
Joined Dec 20, 2007
11,248
The OP asked why is the positive peak much less than the negative peak and I explained and showed that the severe distortion from his transistor that has no negative feedback caused it. In my second simulation I showed that correcting the biasing and lightening the load did not eliminate the distortion but my third simulation did eliminate the distortion. The OP did not want distortion percentages.
I made a typo with the load on my third simulation. Here it is with the same 5.6k ohms load as he used:
elec_eng_55
Joined May 13, 2018
214
Hi Mr. Chips
Yes its from LTspice
