CD4XXX Library For Spice
maker_2023
Joined Nov 20, 2023
199
maker_2023
Joined Nov 20, 2023
199
Ignore post #4.
Per Bordodynov's instructions, I have placed his symbols and sub circuits in the following folders.
Can anyone tell me what my include directive should be. "include cd4000.lib" does not work.
This is where the symbols are.
c:\users\mike\AppData\Local\LTspice\lib\sym\ZZZ\LOGIC\CD4XXX
This is where the sub circuits are.
c:\users\mike\AppData\Local\LTspice\lib\sub\SUB
ericgibbs
Joined Jan 29, 2010
21,527
hi maker,
I get the same error using your asc file.
Will try to locate the problem and get back if I have an answer.
I assume you are using Windows
E
maker_2023
Joined Nov 20, 2023
199
Hi maker,
I did this action to replace the symbol in your asc file, it then works.
F2 > ZZZ > LOGIC > CD4xxx > cd40001b
Try that action and run this asc file.
It looks as though you have a 'path' problem?
E
Yes Windows 11. Still doesn't work for me. Yes I am sure it is a path problem but I have tried everything
that I can think of. In post #5 I indicated where the symbols and sub-circuits reside. Maybe Bordodynov
could assist us.
Audioguru again
Joined Oct 21, 2019
6,826
In post #10, how can the simulation magically produce an output current of almost 9mA when the supply voltage and LED voltages are unknown? The output current of a CD40xx depends on the supply voltage.
ericgibbs
Joined Jan 29, 2010
21,527
Hi agu,
If you look more closely at post 10, you will see it uses the standard CD4000 set, in which the voltage is declares as 5V.
Not the CD4000_v in which the Vcc aka vdd has to be specified.
E
eetech00
Joined Jun 8, 2013
4,723
The supply voltage is specified as one of the symbols' attributes by default (VDD=5), when using the CD4000.lib library.
What is also not displayed is the voltage output level which is extremely low (millivots).
A real part probably would have been damaged.
