Can a 74LS02 NOR package be used in place of a CD4001 NOR in an oscillator circuit?
TY
TY
What is the power supply voltage? What will the oscillator be driving?Can a 74LS02 NOR package be used in place of a CD4001 NOR in an oscillator circuit?
The two parts switch at a different voltage. Most CMOS logic switches from 0/1 at 1/2 the supply voltage which is not "TTL" levels.Can a 74LS02 NOR package be used in place of a CD4001 NOR in an oscillator circuit?
Here is the schematic. Supply voltage is 5 volts.The two parts switch at a different voltage. Most CMOS logic switches from 0/1 at 1/2 the supply voltage which is not "TTL" levels.
Also 74LSxx output has a week pull up.
It will probably will work.
Generally speaking, the answer in no. The CMOS part is more adaptable to being biased into the linear region for use as an oscillator. That said you should consider using an unbuffered part as they have even more favorable characteristics for that application. The LSTTL part is not at all suitable for this purpose.Can a 74LS02 NOR package be used in place of a CD4001 NOR in an oscillator circuit?
TY
If you are never going to build this then it does not matter what you choose since it will never be used.I would rather work with cmos because of all the advantages but is it not a pain dealing
with cmos because of static electricity, especially with solderless breadboard?
No microcomputer involved. I may not even build this circuit. At the present time I am
just researching.
I haven't found working with MOS parts on solderless breadboards to be much of a problem. Ground yourself before handling or use an ESD-strap.is it not a pain dealing
Maybe.Can a 74LS02 NOR package be used in place of a CD4001 NOR in an oscillator circuit?
Celsius versus Fahrenheit | Off-Topic | 134 | |
| M | Inductance values versus voltage? | Analog & Mixed-Signal Design | 3 | |
| J | Voltage versus Current | General Electronics Chat | 5 |
